Owen Geoghegan
It maybe that you added extra security to sign into your account such as a text like this ( your google verification code is 592042).
i had this problem too.
i live in Iran, if you live in same country or at least you are facing filtering too. i would suggest connecting using a proxy like hotspot shield.
this actually solved my problem
i have seen one more solution ,
go to settings and clean all your cache and data from your contacts storage and contacts.
i've seen some people got solved their same problem with that solution.
Anyone else getting this message for syncing gmail account with the phone? Anyone know what it means? Gmail works but calendar and contacts sync only sporadically, and I get this message.
