Exynos abuse question (PLEASE HELP)
NHBass39
840
7
It seems from time to time my phone will run a log from what I believe is Exynos abuse or superuser and will freeze whatever app I'm in till it finishes and I back out of it. Any idea why this is happening? I'm rooted stock rom.
DroidXcon
11,102
3,392
try this, open super user, go to settings, go to default access, select [Prompt]
what apps do you have in the apps section of SU
NHBass39
840
7
Prompt is there. I have debuggerd.exynosabuse, exynos abuse, root explorer, sqlite editor, and titanium backup in the apps. The first one is weird and I never saw that before.
DroidXcon
11,102
3,392
touch debuggerd and deny access if you can , or tell it to prompt you
NHBass39
840
7
I denied access. Hopefully that works. Phone has been great till this started and it only happens once in a while. Thanks a ton for the help as usual. I'll post how it works out.
So far so good. Thanks DroidXcon
Sent from my Samsung Galaxy Note 2
