1812dave Well-known member Sep 9, 2010 3,133 35 0 Visit site Jun 20, 2014 #1 At least on my phone Note 2 & Gear 2
B. Diddy Senior Ambassador Moderator Mar 9, 2012 165,601 4,745 113 Visit site Jun 21, 2014 #2 Are you using the AC app or the AC Forums app (the Tapatalk-based one)? Try going to the App Manager, select it, and Clear Cache and Clear Data. Then open it again, log back in, and see if it's still crashing.
1812dave Well-known member Sep 9, 2010 3,133 35 0 Visit site Jun 21, 2014 #3 The AC forums one. Will do as you suggest Note 2 & Gear 2
jlost Trusted Member Aug 6, 2010 1,507 30 43 Visit site Jun 21, 2014 #4 Samething with me but only if I don't use it for about 2-3 minutes. All though I can use it again.
1812dave Well-known member Sep 9, 2010 3,133 35 0 Visit site Jun 21, 2014 #5 I get the closed message for a_c forums while I'm using other apps so that sounds sort of like what you're experiencing Sent from my SCH-I605 using AC Forums mobile app
1812dave Well-known member Sep 9, 2010 3,133 35 0 Visit site Jun 22, 2014 #6 It didn't help. It just closed on me while I was viewing the forums Sent from my SCH-I605 using AC Forums mobile app
B. Diddy Senior Ambassador Moderator Mar 9, 2012 165,601 4,745 113 Visit site Jun 22, 2014 #7 Email the developer and let them know! apps@mobilenations.com
1812dave Well-known member Sep 9, 2010 3,133 35 0 Visit site Jun 22, 2014 #8 Will do Sent from my SCH-I605 using AC Forums mobile app
Golfdriver97 Trusted Member Team Leader Moderator Dec 4, 2012 35,367 113 63 Visit site Jun 22, 2014 #9 Been seeing the force close myself. I just sent a report when it happened. From a Carbon M8 and AC Forums app
1812dave Well-known member Sep 9, 2010 3,133 35 0 Visit site Jun 22, 2014 #10 Just emailed them Sent from my SCH-I605 using AC Forums mobile app
