Can anyone point me to a car charger that charges as fast as the stock wall charger? Preferably something inexpensive on ebay? The one I'm using now just barely keeps when I'm using GPS.
I'm using a Qmadix 1 Amp car charger I got at my local Verizon Store. I've used it with my GPS going and it actually charged it more than just keeping up with it. So I would recommend it.
Ansextra, I only used it once so far with the GPS, and it went from 76% to 80%, not much, but I was driving maybe 20-25 minutes. At least I know it's not just standing still or just keeping up. I have to use it on a longer drive, which will really test it out.
There are many, none of the iPhone so called universal USB chargers will work.
They us a iPhone protocol and limit the output regardless of the rating.
You need a 1 Amp charger for non-iphones.
I use the "GTMax Metalic Silver 2-Port USB Car Charger Adapter", just plug that in Amazon. Should be under $10 and comes in several colors.
One side is iPhone protocol and one side is non-iPhone.
Charges even while I have everything running, Navigator, Phone, Radio App and on a road trip for hours with screen lit the whole time.
I use the other side to charge my backup hands free. Even though its marked 2.1 Amps it will not provided that charge for an android.
The two data pins are shorted in the charger for non iPhone chargers and not for iPhones. Many generics use the iPhone protocol and say they are universal, they are not.
Use the 1.0 Amp non-iPhone side and it will work great.
Don't like that one, check the write ups. Look for one at 1.0 Amp and not for an iPhone.
