So I see lots of threads about WiFi turning on randomly, but my problem is different.
WiFi doesn't turn itself on, but it resolutely refuses to stay on once I turn it on and connect to a network. It'll work for a few minutes, then randomly disconnect from my network. Sometimes it'll reconnect. Other times it won't, and I need to manually toggle WiFi off then back on to get it to reconnect.
This is when the phone is literally no more than 5 feet from the router, sitting on the desk next to the router itself.
My router normally works with everything else flawlessly, and I turned off all the other Wi-Fi connecting objects to see if it was some sort of DHCP issue (it isn't). I also tried both the 2.4Ghz and 5Ghz connections to see if it was one or the other; it happens on both (and my router can run both simultaneously so it's not a 2.4 ghz device connecting and eliminating the 5ghz connection).
Any advice? Is the WiFi antennae or chip or whatever in my new S3 hosed? Do I call for a replacement? Is there something obvious i'm missing in the phone settings or router settings that might be causing this issue?
