Does anyone know if its possible to install Kies Air on the Verizon Note 3? I'd love to be able to send texts from my phone instead of using Google Voice.
You can find it in the Google Play store I think. My experience has been if your phone isn't compatible it will say so in the description or it won't install.
Sent from my SCH-I605 using Tapatalk
You should have a microphone key on your keyboard. Long press on it and you should be able to talk your texts instead of typing. In case that helps not sure that's what you're looking to accomplish.
I have a Verizon Note 3. Kies Air is installed by default in the Apps drawer.
Crazy, I searched in the usual places. Even Samsung Apps didn't show it.
This one might work. *WORKING Kies Air Apk for ROM: N7000XXLSA & N7000XXLSC* - xda-developers
An alternative is AirDroid.
