dmaynard83
60
I haven't been too impressed by the battery. I have most settings on and display is on auto.
I'm going to turn the display down as that is what looks like is draining a lot of battery.
I usually stream Pandora at work and get around to 60 percent by lunch on my note 2.
Let's see if low display settings will fix it.
Sent from my SCH-I545 using Tapatalk 2
Coffeeman
88
Try installing Qualcomm's Battery Guru, in the App Store. Specifically designed for Snapdragon processors. This has increased my battery life by an average of 15%
majorpayne
872
41
How many days have you had the phone. If i recall right it takes 3 charges to truely get optimized. to many varibles right now to tell why your battery is at 23% after almost 7 hours
Coffeeman
88
It monitors one's usage patterns, then will close apps based on this data. Also uses GPS to turn wifi off when not in a "home wifi" location. I like it because it is developed by the same people who make the s4's quad core processor.
glock813
Active member
Jan 12, 2011
33
The battery has definitely gotten better with time! The first day I only got about 7 hours and now I am almost 24 hours with average use! It seems like it took a couple of days to settle in...
LdotAdot13
557
15
18
I've been pretty happy with my battery. Over 3 hours of screen time!
Sent from Cletus the S4 using Android Central Forums
smokedog87
