You are correct, Mustang. If you're on Beta 3, don't toggle off mobile data or try to add a carrier. In my case, I lost LTE and tried to toggle mobile data. That caused me to lose data altogether and neither Google nor AT&T could fix. I opted out back to Pie and all is well. I might try the beta again, but this was one major bug that takes a FDR to correct.I have come across if you go to mobile network in settings and try to add with the + sign next to it you will get no more mobile data and either reinstall beta which I did or possible factory reset
Yeah was going to.take my Att sim and put my tmobile that's when it wouldn't give me options for my carrier, so I rolled back to P and then enrolled in Q again and wont try that again .You are correct, Mustang. If you're on Beta 3, don't toggle off mobile data or try to add a carrier. In my case, I lost LTE and tried to toggle mobile data. That caused me to lose data altogether and neither Google nor AT&T could fix. I opted out back to Pie and all is well. I might try the beta again, but this was one major bug that takes a FDR to correct.
I tried looking couldn't find anything useful, could you explain how you fixed yours ? Thanks
That is exactly what I have read in the issue tracker before.
https://www.androidpolice.com/2019/...uld-disable-your-sim-card-but-there-is-a-fix/
