Have a Razr-M (XT907) and the over the air update to KitKat 4.4 was not installing. It would download the green android man would appear and start the download, but he would fall over dead and it would fail. Tried it after a system restore to original factory default still failed. So I tried doing it manually using RSD Lite (had to remove the "getvar" line in the xml file to get it to work. It completed 15 out of 20 steps (not sure how many steps there were) and on Number 16 (system.img) is says Phone returned fail. I tried to flash the previous version (since that had updated successfully but that failed on step 2). So then I copied the previous system.img to the new 4.4 install folder to see if that worked and that also failed.
So now I have a phone that of course does not boot. But it responds fine to RSD Lite, just won’t get past the system.img flash.
At this point, I would be fine getting back to the previous version or if someone could help with updating to current version that is fine. The phone is not rooted although I would be fine with doing that. Whatever get its working again.
