although I like the look of Lollipop it is slowing my tablet down like a constipated snail.
Can we have these instructions in English please?
yes but it *is* complicated for newbies (like myself). It's frustrating, esp as 4.4.4 was suiting my needs just fine, I just got caught up in the hoopla and didn't read any comments. I will be rolling back to kit kat on my n7 2013 but have spent hours watching youtube tutorials and downloading the sdk, fastboot ETC ETC.
Agree with you 100%! Just flash your choice of Kitkat ROM via Odin. Problem solved. You will of course loose your data and everything else, so just backup before, and restore after!I agree with all of you 100%. Lollipop is gross to be honest. If I wanted everything white, flat and ugly (and uncustomisable) I'd buy an iPhone. Phone now freeze up, notification bar is ugly, cant view the contents without clicking on it, when new message received my LED light wont light up, screen wont wake up as well. How can i downgrade without doing factory reset? Android should fix the notifications settings, keep them as they were. The update would've been a lot better without changing notifications settings and layout. We have to do so many steps know in order to receive a notification, keep it like the KitKat version (i mean settings wise).
Installed Lollipop on my Nexus 5 yesterday.
Now Email sucks. Twitter is not working.
Some controls have been hidden(moved further back).
White backgrounds are too harsh... etc etc.
I want my KitKat back. :'(
Any ideas on how I can get there ?
No, fortunately you can get rid of the notification. I did so with the 5.0.2 notification, thanks to instructions from Brosko, another participant on these forums. Here's what he said:Don't know what the point of rolling back to KitKat is, since once you do, Google will automatically download 5.0 and then it will stay in notifications reminding to install until you accidentally hit it.
"You can disabled the notification for the update by long pressing it then selecting app info and then when it takes you to the play services app info screen uncheck the enable notifications box to disable notifications."
I followed his instructions, and the 5.0.2 notification hasn't returned. I was at first worried that all notifications would stop, including those from Play Store, but that's not the case. The only notification that no longer appears is the one for 5.0.2. My Nexus 7 (2013) is very happy to stay on KitKat 4.4.4.
I hope this helps.
I'm liking lollipop quite a bit. I used nova launcher to give me the KitKat app drawer back but other than that I think lollipop improved everything.
Hi every one.Warm Greetings to one and all,
I'm sorry to say but it's not that easy job, to downgrade from Lollipop to Kitkat So....
The best part is that better stay in Lollipop and wait for further Update from Google. Eventually you can change the custom settings for your desired problem. They are specified if you cant find them, Definitely some one will help you in solving them.
Some of the major 'Cant find' difficulty in Lollipop are:
1.Photos instead of gallery
2.Extra-long-log in-time (extra swipe to log in)
3.extra-google-apps
The only Positive is:
1.Having a Torch with out any app.
