Way to display battery level?
tr-1
405
I forgot the APK name that did this for KitKat but I specifically remember you could install this little patch and it simply exposed the built-in battery level in the notification bar. Is there such a thing on L?
Thanks
I use battery widget reborn and it displays a notification of your current battery percentage. Works great too.
Thanks. I'd like to use the stock one though. No idea why Google hides it by default
kimswid48
