I just got a Fiio X7 Mark II, it comes with Lollipop. I installed Spotify, Apple Music, Play Store, and Chrome after system updates.
After about 2 days, I get a storage space running out notification and apps cannot download anymore. The device has 64GB of internal memory, no SD Cards are inserted.
In the storage setting, under "Internal Memory", it says available only about 1.9GB, but 2MB remaining space. Under "NAND Flash", there is 55gb or something, with 54GB free space.
Something tells me the internal memory is divided into a tiny partition and everything is installed on the tiny partition. When I plug in the device to a PC, I get the full 55GB or so and the apps like Spotify are on it, in the Android folder. So far I only downloaded a small playlist, so it's about 1.9GB. So by that it seems spotify is in the 55GB area, yet it says full.
On ES File explorer, I can check some other folders when I go to "internal", but it doesn't seem like the apps are installed there.
This is very annoying and there's no fix on the internet. Just clickbait articles like "7 ways to fix storage running out" with useless solutions like clearing data and cache.
Thanks in advance, would really appreciate the help.
