M mikegen79 Member Oct 11, 2016 6 0 0 Visit site Oct 11, 2016 #1 I just want to be sure wether 4g comes marshmallow version. Thanks
TwitchyPuppy Trusted Member Feb 18, 2015 849 0 16 Visit site Oct 11, 2016 #2 Yes. The network speed has nothing to do with the OS.
M mikegen79 Member Oct 11, 2016 6 0 0 Visit site Oct 11, 2016 #3 So, you mean if I upgrade from lollipop to marshmallow my phone will not support 4G LTE? @ puppy
bespinct Well-known member Apr 24, 2010 832 18 0 Visit site Oct 11, 2016 #4 mikegen79 said: So, you mean if I upgrade from lollipop to marshmallow my phone will not support 4G LTE? @ puppy Click to expand... No, they mean that 4G is a feature of the phone, not the operating system it runs. If it supports 4G with Lollipop, it will support 4G with Marshmallow.
M mikegen79 Member Oct 11, 2016 6 0 0 Visit site Oct 11, 2016 #5 Now, I understand, thank you very much @bespinct. Please, how can 4G work with or be supported by my phone, Lollipop version. ?
bespinct Well-known member Apr 24, 2010 832 18 0 Visit site Oct 12, 2016 #6 I have no idea what phone or carrier you have, but if it isn't 4G now, it won't ever be 4G.
M mikegen79 Member Oct 11, 2016 6 0 0 Visit site Oct 12, 2016 #7 Yes, you are right, it's does not with 4G. The name of the phone is infinix hot 2.
