Why is my battery life so horrible?
Theo Donacik
84
My At&t galaxy s7 (on android 6.0.1) has horrible battery life and standby life. I have seemingly tried everything and followed all the usual instructions, like turning on airplane mode (which seemed to work for standby time but I wouldn't get texts or notifacations so I hope it doesn't come to that), wiping system cash, and much much more, but i still struggle through every day with only around 15% by the end, while my dad does none of this in his s7 edge and ends up with 60% on a BAD day.
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,367
113
63
Welcome to the forums. It's always difficult to determine battery life as people use devices differently. Something as simple as Facebook can make a difference in battery life.
Can you post screenshots of your battery stats, please?
Theo Donacik
84
I've been using my phone sence 9, and I've been using it more than usual (and I don't usually play as much pokemon go ;) ) but is is only 5:20 and I'm already at 5%. Normally I have it idle in my pocket at school and that drains mabey 10-15 percent of my battery because of cell standby over the corse of 6 hours
ManiacJoe
Trusted Member
Aug 5, 2015
6,326
3
38
Expand the "android system" and "android OS" entries to see what is in them.
How bad is the cellular reception where you are at? Your attached image suggests it is not good. If it drops into the "bad" range, the phone is going to use more power to reach a cell tower.
Theo Donacik
84
By expanding android system and android OS I can see that most of their drain is coming from the CPU (although I really don't know much about this subject). Is there any way to reduce this? Also is there any way to fix the cellular problem without just using airplane mode?
jefbeard911
Active member
Oct 1, 2012
32
Pokemon GO is a battery killer.
I'd suggest you remove it for a day and see what your battery life is then. My guess is that this is the culprit.
Theo Donacik
84
No, today is the first day I have played it in a long time, and my battery has been like this every day, so it has to be something that is used every day. I just got an app that tracks battery usage, and so far it seems like the usage is coming from several diffrent things, but nothing that seems like it would use sooooo much power
tivativa
