Any apps that show what is using your battery SPECIFICALLY? Stock app shows what's generally using it. I am trying to figure out which apps are draining my battery most. Thanks.
Can you explain what you mean by "generally" and "specifically" in this context? The battery info screen will definitely tell you which apps are draining your battery the most.
I want to know how much battery each and every app is using so I can tweak each to optimize battery life. The stock app just shows a GROUP of apps and how much battery they used COMBINED.
