I have two old devices from an unknown manufacturer Vivax, one Android 4.1, the other 6.0. Both have the option to self-switch off and self-switch on at a set time. I bought a Vivax TPC 102 with Android 9 Pie, - there is no such option! Is it up to the device or up to the android version?
The second question - the tablet is active all the time and on the charger, mounted on the wall. It happens that it suddenly stops charging, which I notice when the battery is empty, so I have to plug out and then plug in the charger to start charging again. Would a stronger charger solve this problem?
