how do I prevent galazy store from using battery
  • Start date Start date
Welcome to Android Central! Do you ever use Galaxy Store? If not, go to Settings>Apps, tap Menu>Show System, select Galaxy Store, and see if you can Disable it.
how do I delite this app
The galaxy app store continues to be on and runs down my battery how do I delete it ?
tsmtool
