How do I record stereo audio from a record player RCA/phono sockets
Gob Shite
Active member
Feb 24, 2020
43
8
How do I record stereo audio from a record player RCA/phono sockets to usb socket on Huawei mate 20 pro?
Solved. For anyone with the same challenge.
Buy a stereo phono to 3.5 TRRS jack which carries headphone AND MICROPHONE
Buy a 3.5 jack microphone splitter
Buy a 3.5 jack to USB C
Download Open Camera - This has a video setting to enable recording audio from an external microphone
Voila:
VidJunky
5,615
411
83
I found this with a quick shopping search... https://www.googleadservices.com/pa...iNmNeoycPxAhWSHM0KHRsBBlwQ9aACegQIARBL&adurl=
Alternatively there are other analog to digital products out there that do similar stuff. Depends on how much you want to spend. If you have an older PC they often have RCA inputs, most of the ones that don't still have AUX (microphone) type connections as do many laptops. I can usually find double male 3.5mm cables at my local Big Lots for $3 to $8.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,606
4,755
113
Your link didn't show up -- can you edit the post or reply with the link?
VidJunky
5,615
411
83
Not sure why it wouldn't work for you but I've been there too. Anyway you can see the link landing in the image, it was only meant as starting point.
Gob Shite
Active member
Feb 24, 2020
43
8
Voila:
