Is there a way to lengthen the timeout on Android 12 beyond 10 minutes?
JayArras
I recently upgraded my phone and was able to use Android 12. On my Samsung Galaxy S10, the longest screen timeout I am able to set is 10 minutes. On my previous J15, it was 30 minutes, which is much more preferred on long car trips. Is there a hack or utility available when I can modify this?
Only thing I'm aware of is the ability to have the screen never turn off while charging ... that setting is under developer options.
Sent from my Samsung Galaxy S22 Ultra 5 Gangsta Alpha Omega Supreme
Welcome to Android Central! It seems to be dependent on the device, because my Pixel 7 Pro can be set to as long as 30 minutes as well.
You could try an app like Screen Alive.
