A
AC Question
I'm considering buying the Moto G 4g/LTE. Will it work on the Three network (including 4g) in the UK?
Thanks everyone for the responses.
I live in London and I would buy the phone on Amazon.co.uk.
My partner has a Samsung S4 Galaxy with Three and she gets 4g coverage at our house.
On the 3 Wikipedia page it lists these frequencies:
2100 MHzUMTS/HSDPA/HSPA+/DC-HSPA+423G
800 MHzLTE (from 2014) 4G
1800 MHzLTE
On the Motorola Moto G landing page it lists these modes:
4G
CDMA: 850/1900
UMTS: 850/900/1700/1900/2100
GSM: 850/900/1800/1900
This seems to suggest it will work with both 3G and 4G (provided the network coverage is available in my location), is this correct?
Thanks everyone for your help.
I had read many networks/carriers in the US have phones set up for the carriers own frequency bands only, and cannot be moved across.
With the exception of individual devices like the Nexus 5, this is very true. AT&T and Tmobile are getting a little better at sharing bands, but it more depends on the phone and how old it is. If the phone is from Verizon or Sprint, usually the phone is stuck to that specific network.
It depends on how 3 deployed their 4GLTE network. I am not that familiar, though on Verizon, they use the 700MHz nationwide in the usa, and slowly deploying 1700/2100 MHz first in high load areas.
Keep in mind that 800mhz would be better for building penitration too.
If 3 deployed both 800 and 1800 in a number of areas, my recommendation would be to find a device that supports both bands to get the best coverage. If you only need coverage at specific locations then you can always buy it and test to see if it has coverage where you need it.
Sent from my Verizon Samsung Galaxy Note 3
1800 MHzLTE
4G
CDMA: 850/1900
Btw, sounds like the Moto g is an international version, not a UK specific version, since it doesn't support 800 MHz, which is only used in region 1. 1800 MHz is used in all 3 regions, but to varying degrees. Of note, the Verizon iPhone 5s which is factory sim unlocked does support both 800 and 1800 MHz. Nice to know if I ever go to the UK. The att and tmobile versions support as well but are sim locked.
