Samsung S5 Battery Dying Quickly
A
AC Question
I just got my Samsung Galaxy s5 only two weeks ago. I've noticed a rapid decrease in battery life so I've taken steps to curb the decline. I've taken the sync off, don't let it use data unless on wifi, even stopped background data from being used. Before I went to bed the other night it was at 20% charge so I turned on the super saver battery mode and it told me I had two days worth of charge. When I woke up not even 7 hours later, my phone was completely dead. What is going on? Is it something faulty with the battery or am I not doing something right?
belodion
Co-Ambassador Team Lead
Moderator
Jun 10, 2014
39,391
255
83
It could be a bad battery, USB cable, or charger, or it could be something else. Let's deal with the battery first...could you charge fully, use until you feel a recharge is necessary, then before you recharge, post a screenshot of the battery usage?
ajungbluth31
I can try that and get back to you. Today is the last day of my two week period where if I need to return the phone etc I can do it without being charged so I'm going to go there tonight and see what they say for now.
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
1) Not "until you feel a recharge is necessary", but until the phone tells you to recharge it.
2) That probably won't show anything helpful - the screen and Android System are probably using most of the battery, and that's normal. If some other app or function is using most of the battery, that would most likely be the problem.
3) The battery should be conditioned. (That should be done to every LiIon battery you don't know the condition of.) Fully charge the battery - until the phone tells you to remove the charger. Use the phone without recharging it until the phone tells you to recharge it, then fully charge it. Repeat that cycle (full charge, full discharge) 3 times.
4) The best battery life (time between new batteries, not time between charges) occurs when the battery is charged at about 40%-60% discharged. Don't blame the manufacturers, that's simply how the laws of physics and chemistry apply to Lithium Ion batteries (and they're the most power dense [most power in the least volume] batteries we currently have).
(BTW, although Ihaven't done ny tests, I don't think that "super saver mode" in the S5 is too much more than a gimmick. It turns off certain functions [which you can do by hand], but getting 2 days from a phone you're actually using, these days, is asking a bit much for the stock batteries. I can easily get 3 days, sometimes 4 days, if I keep my Note 3 on normal power saver, with the screen turned off, in Airplane mode, and don't use it or have any programs doing anything. But make phone calls, or even read web sites all day long, and you're not going to get 2 8-hour days on most phones.)
BTW, it's not "the S5" that's the problem, but it can be your S5, so that 2 week period would be the difference between having the phone replaced with a new one or a refurb. The S5 is a good phone, and not prone to abnormal battery use. (So if you exchange it for some other make or model phone, you're starting with a whole other set of quirks, and the 2 week period probably won't reset.) Between the S5 and my Note 3, I still prefer the Note 3, but I'd feel a lot safer using the phone in the rain if I had an S5.
belodion
Moderator
Jun 10, 2014
39,391
255
83
I think you are wise because no new device should be giving such trouble but if you've got time between now and then try pulling the SIM card which is one possible cause of battery drain, and see if that seems to help.
