How will I fix my note 2 hanging problem ?
A
AC Question
It's all about my phone which is - note 2 . My phone has got a problem like its been stuck at the screen which shows - downloading do not switch off the target I guess . So what should I do to fix this problem .
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,606
4,755
113
Welcome to Android Central! It sounds like you booted into Download Mode (which happens when you power on by pressing Power, Home and Vol Down). As long as you're not connected to your computer and actively flashing a ROM, you can power the phone off again, and then power on normally by just pressing the Power button. If there's no clear way to power off, just press and hold Power for about 10-15 seconds until the phone shuts off.
Were you trying to get into Recovery Mode instead?
RandyRoyalty
