What extra adaptors do I need to make a ASUS C100 flip top work on UK 240v. power supply?
A
AC Question
I have purchased a new ASUS C 100 Fliptop from the USA and am waiting delivery. I understand that the electricity supply is different in the UK? Will my device work in the UK? can anyone help please?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,602
4,751
113
Welcome to Android Central! Virtually every device's power adapter these days is compatible with 110V and 220V. When you get it, look at the power adapter, and see if it says 110-220V--that means you don't need a voltage converter. You will, however, need an adapter so that the plug can fit in the UK sockets (which should only cost a couple of dollars or so).
Non
