A AC Question Jul 3, 2016 #1 Help me disable the DU battery saver on my Samsung cell phone. I don't know what model it is.
Javier P Ambassador Feb 21, 2014 19,480 3 0 Visit site Jul 3, 2016 #2 Welcome to the forums. First go to settings - security - device administrators and make sure this app is unchecked there. Then go to settings - apps - select DU battery saver - force stop - clear data and uninstall. Upvote 0 Downvote
