A
AC Question
Hi everybody,
I have this problem with my Samsung Galaxy A8 Duos. Power button of my mobile is not functional and now it is turned off due to battery drainage. I charged the battery but as the power button is not working so my mobile cannot be turned on that way. I have checked almost all the forums on the internet but could not find any solution. If there are any solution to such state that is for the mobiles which have removable battery while my mobile has non-removable battery. So it is switched off for a week or so. Any kind of help in this regard will be greatly appreciated. I am in need of my mobile so much. Please help.
Thanks.
Regards: Shakir
Thanks.
Regards: Shakir
