How can I separately adjust volume for ring and notification?
  • Start date Start date
A
AC Question
Since the update I noticed both of our Droid Turbos have the problem. When I adjust the volume for ringer or notification or system they all change. I tried to adjust them separately in settings and using the slider widget. the other volume adjustments are fine just these 3. They use to work separately before the updat to the operating system that occurred recently. Maybe it's a bug that they will fix eventually? Hopefully.
If you wipe cache partition after updates, it will refresh the phone, get rid of residual programs and hopefully make your device go faster. If that doesn't fix it, you may have a bug in the new update....
boyl99
