Note edge 2 power saving icon on settings app manager missing
  • Start date Start date
A
AC Question
My samsung note edge have 2 power saving icons it should be 1 only and the application manager icon is missing? My note edge running at 5.0 version lollipop
Welcome to Android Central! Where do you see the two power-saving icons -- on the homescreen, in the App Drawer, or in the App Manager's app list? Where are you looking for the App Manager icon? It should be in the main System Settings menu.
What does that message "SM915V not to F" mean? Are you saying that your Note Edge is actually the SM-N915V variant, not the N915F? If so, that means you or somebody else flashed the N915F firmware to the phone -- and installing the firmware for a different variant can cause various issues.
kabarba2
