problem everybody is having with the repeating on speech to text
Don Sprague
problem resolved.I had the problem with my text-to-speech repeatingand all I did was go and erase updates on Google and erase updates on text to speech and it is working fine no problems the only difference is the color of the background went from light to dark where you push the button where you can speak or pause other than that is working perfectly
How???
doesnt work, tts is something different
rosannejoy555
