I have an s7 edge, how do I lock the pull notifications on the lock screen?
  • Start date Start date
A
AC Question
I tried to do it through the settings, and it doesn't have any option for that. Any help and I would like to lock my edge apps as well
Which app is pulling? You can go to Settings > Notifications on lock screen, and enable whichever apps you want to allow notifications for.
If you mean you don't want the notifications to be able to be swiped away, that's dependent on the app generating the notification.
