A
AC Question
Hello to all! Recently I bought an used Samsung S6 Edge +, it have Marshmallow Android; the phone as far as I can see is original and have no troubles in general and is not Rooted, however there are 3 things I am having troubles with:
1.-The Phone is fast however between menus I can see how it sometimes freezes for a second and then continues, something don´t even happen on my old Galaxy S4.
2.-Youtube plays for few seconds, then freezes with the sound still playing; sometimes I have to go back or forth on the video for it to resume, sometimes it resumes by itself after a couple of seconds but with frame and audio desync and sometimes it just says "An error has occured" so I have to tap for it to resume.
3.-Every time I turn off my Phone it forgets the password for my Wi Fi, something is VERY annoying and it have no option for remembering as far as I can see.
Now I already tested several options but nothing works so far:
1.-I already deleted Youtube app, reinstaled it, used the stock app, the latest one, grantes storage access to the app, tested from inside a Page in Chrome, etc.. nothing works.
2.-I already turned on Developer´s Options and enabled and disabled (tried several setups) "Force GPU Acceleration with Hardware" and these other "disable layers" options, and it doesn´t works.
3.-I already closed all apps in the background, wiped partition cache, and even did a Factory Reset, used the phone in Safe Mode, disabled the Ant+ and S Health, Apps, nothing worked.
I am really annoyed by this and so far nothing seems to fix it, I am about to discard the phone but I don´t want to as it looks really great in comparison with my S4, but with these faults I find hard to keep it, specially when my old Phone can do everything without any problem but a High End phone can´t apparently.
Any advice will be great, please!!
