Samsung uses a wire in the charger to indicate to the phone that it's connected to a plugged-in charger. Apple doesn't. So in the iPhone charger, the phone is charging as ig it was plugged into a computer's USB port - 450mA.
iPhones don't support rapid charge, the Note 5 does. The Note will charge faster on a rapid charge capable charger, which the iPhone wall plug doesn't support.
