A
Android Central Question
Alcatel IDEAL unlocked Android phone stuck to 2g/Edge
I bought an unlocked Alcatel Ideal 4060a (AT&T) model from Lazada Philippines a couple of months ago, but problem is that the network doesn't change at all its always at 2g/EDGE no matter what i do or which network i put inside the phone.
Am currently using Globe which is a 4g Sim card and the phone is unlocked to any network.
And there is no option in the settings that you normally choose from your preferred network mode.
So i stated googling for the solution when i came across this code (*#*#4636#*#*) which i can use to change my preferred network, but whenever i change it, nothing happen, i mean nothing at all, all it does is that, when i select "only WCDMA" i will not get service/network, when i select "LTE only" no network, the only thing that work is GSM or WCDMA preferred.
I need your help!!!
I need your help!!!
