Using Smart Switch to transfert data from Galaxy S3 mini to Galaxy A5 t
  • Start date Start date
A
Android Central Question
After using Smart Switch to transfer data from Galaxy S5 mini to Galawy A5 the data from the Calendar are not vivisble any idea ?
Smart Switch started twice without error.
The data in the calendar should be what's at Google Calendar . If that didn't sync up, check your Google account (in both phones) to make sure that you have calendar sync enabled (and that the Google account is the same in both of them).
