    my galaxy note edge continue re starting but not open
    04-22-2018 01:48 PM
  2. Rukbat's Avatar
    That could be a bad battery (it starts, shuts down, the battery comes back, it restarts, etc.) or it could be corrupt firmware.
    Try booting into recovery or download (one of the volume buttons + Home + Power) (it doesn't matter which volume button - up will boot into recovery, down will boot into download) to see if the battery can keep the phone on for a minute or two. If it can, it's probably corrupt firmware, and you'll have to reflash the ROM. See [Samsung] How to flash Stock ROM via ODIN. Samsungs are easy to reflash, you'll just die of boredom waiting for it to set up after it flashes. Have a good TV show to watch or something.
    04-22-2018 01:58 PM
  3. Golfdriver97's Avatar
    I can't remember if this device has a removable battery. If it does, it's possible that the battery has swollen and can shift around, creating a disconnect, that mimics a reboot
    04-22-2018 02:52 PM
  1. Switch to S9+ or wait for the Note9?
    By V-Ko in forum Samsung Galaxy S9 & S9+
    Last Post: 07-16-2018, 07:54 AM
  2. After Oreo update do not disturb create rule problem
    By bonkerstheclown mcpickle in forum Legacy Android & Other OS's
    Last Post: 04-23-2018, 12:19 PM
  3. My key board stop running on my phone what to do
    Last Post: 04-22-2018, 02:13 PM
  4. How do I turn off the lock
    Last Post: 04-22-2018, 12:26 PM
  5. when i get a text, it comes in as pic
    Last Post: 04-22-2018, 12:24 PM
