Android tv box wifi issue, says disabled.
Scoobyrogers
I have a Leelbox Android TV box. Older one is 6.0 android. It worked fine u til a new internet company installed a new router. Now when I connect, it says Saved, then immediately says DISABLED. I tried connecting with same kind of box , newer with 7.1 Android...same thing happens. I tried connecting to my Android phone Hot Spot...same things, SAVED, THEN DISABLED. No connection. I tried connecting with an iPhone Hot Spot and bam...it connects and works fine.
So I thought it was the router, but when it didnt connect to Android phone Hot Spot, but did connect to iPhone Hot Spot...I'm confused.
What settings can be checked on the Android TV Box. And the Router. ??? I will try to connect manually next.
Anyone come across this ???
sukarisw10
