Hi, I have a problem with my SD card..
  • Start date Start date
A
Android Central Question
I've tried everything but everytime I move skmething to my SD card it gets deleted and just shows that the file doesn't exist. I tried restarting my phone.. It didn't work.. I've trued unmounting mt SD card and that didn't work.. I've tried EVERYTHING I could find..Please help. Thank you
It sounds as if the SD card port is loose. See if you can slip a piece of paper in with the card, on the non-contact side. If that doesn't do it, try a different card (or let someone try your card in their phone - see where the problem goes - with the phone or with the card).
If the problem is with the phone, it has to go into a repair shop. (And if they offer to replace the motherboard, check another repair shop.)
nonyabizness
