A
Android Central Question
Hi all, Just got a new Oppo R15 Pro running Android 8.1.
When ever I turn on any of the accessibility options on the status bar it says "Accessibility" and I can't remove it.
The only setting I really wan't is to be able to use the power button to hang up calls (didn't have this problem on my old Pixel).
Is it possible to have this option on without the word "Accessibility" taking up half the status bar?
Cheers.
Cheers.
