Android for Work - Missing battery setting.
  • Start date Start date
A
Android Central Question
Hi, I am missing an urgent setting in Android. I'm using Android for Work and my Mail Client (Nine) is installed in the Work Profile. So if I go to Settings -> Battery I have to choose the profile, so I click on Work, and here, I have not the Setting for "Launch" (at Personal I have this Option, but the App is not listening here, because it is installed under Work Profile)
The problem is, that the App is not start automatically, I have to set the option manually and activate all settings.
Other Settings like "Ignore battery optimization" is the app listed and I can set to "allow". But unfortunately, it get killed and not starting automatically.
Skywalkerbc22
