A
Android Central Question
Samsung A6 december 2018, version Android 9. Kernel 3.18.91-15516909
The slider doesn't go lower (to the left) when I want to lower the volume during a call.
Even when visually there's still room for it on the slider bar? It looks like the slider is fixed to a minimum threshold that is above the actual minimum and prevents you to reach the actual/visual minimum!? In practise I would like to be able to lower the volume during a call to zero(mute in this case) or as close to zero as I would like.
