A
Android Central Question
Hey, so I have a wireless charger and at one point in time it worked fine for my phone. And now whenever I plug in the wireless charger the LED indicator blinks a turquoise color at the same time 3 times fast over and over. And it doesn't charge my phone. I noticed that the true LEDs that are lighting up inside are blue and green the same time, but that's probably just to mix the color when it shows up through the plastic covering. I'm kind of frustrated with this thing. I'm not using the same adapter as last time, so I don't know if that could be the culprit? I looked at the input and output and it's really not that far off, in a sense that should work just fine. And I know about voltage and amperage and stuff like that and so I don't think that should be the problem... I don't know very much about circuit boards either, so maybe it is if this thing is just being stubborn because it wants the exact input? I didn't want to waste my money on a new adapter if you guys know of any other problem it might be having because I can't find the old one.
