Galaxy S7 won't turn on, won't force restart, and the blue led is solid.
Joey Hill4
5
I was scrolling on reddit when my phone froze, some of the pixels changed colors and the phone was unresponsive. I tried to force reset it then and it started to boot but would turn off and then try to boot again. it did that a few times and is now not responsive to anything. the battery was about half full. I have no 3rd party apps. the blue led is still solid.
Welcome to Android Central! The solid blue light is typically a bad sign -- either a bad battery or a failing motherboard. Try pressing and holding Power and Vol Down for about 30 seconds, then wait a few seconds, then press and hold Power again for another 30 seconds. If nothing happens, tou'll probably have to bring the phone to a repair shop.
Hi , welcome!
Yes we can
(Im not very familiar with forum posting so forgive me if I am doing this incorrectly) All parts of the phone are original factory parts, I haven't replaced anything.
B. Diddy, I tried the button presses you suggested and nothing happened. thank you all for the help, im going to take it to a repair shop. hopefully I don't have to get a new phone.
Do you have an SD card in the phone? If so, turn the phone off, remove the SD card, then turn it on again. (The blue light is also a "hard drive access" indicator - but for storage since there's no drive in the phone. If a file gets looped in the SD card [they don't, normally, in internal storage], the light will stay lit until forever.)
if the blue light still works, try plugging the phone into your computer and see if the computer sees the phone. if it does, you might be able to recover files.
trixie909
