I recently bought the Zenfone 2, i am using it for 2 weeks and overall i am satisfied. One thing i noticed though that people are having issues with the battery as it dosent last a day for them even though its 3000 mah, so i decided to experiment with my device to see how to keep it going without charging and of course with normal usage. Below are the steps that you can also follow to see how things work out for you:
1) After using your phone, clear all the apps from the recent items(click the lower right button and remove all the running apps).
2) CM(Clean master) app provided with the phone is great, use it as wisely and your phone will perform much better.
Use CM to regularly clean your junk files as well as use the one tap boost option every time after using your phone and before locking it.
3) Use the Auto start manager to check which apps starts when you start your phone, keep it to minimal, i only kept social networking apps like (Facebook, Watsapp etc.) in auto start option, it will help a lot.
4) Go to Setting -->App and disable the ones that you don't need like I disabled apps from google like google drive, google music etc.
5) Disable WIFI or 3G data when you don't need it, disabling it for limited time when you don't need it will save a lot your battery's juice.
6) Also disable location(GPS) when you don't need it.
That's it guys, i followed the above steps and my phone had normal usage in 48 hr window like i played games for like 6 hrs,listened to music for 4 hrs, used net for 8 hrs and was on call for 2 hrs. But after 48 hrs there is still 10% battery left in my phone. So good luck and let me know if it works out for you.
