powr wireless car charger
deppi0
46
I can't get myself to buy this item when the information on the site is very basic. No reviews anywhere online... Almost looks like a scam
hs1125
I bought two and they arrived in three days. Works very well. Love the option of either vent or dash mount. If you want to use Android Auto you can plug the "c" cable in your phone as it will sit in the mount. The Android auto option won't work using the wireless charger part. If you just want to charge wirelessly it works well too Using a fairly large phone in it. Note 9
Borarjti
375
yes I received the 2 I ordered in less tha a week, works phenomenal so far, only gripe I have with them is with my 2017 Honda having the radio antenna in the windshield the wireless charging interferes with the radio signal, so I just use Google music or apple music, also make sure if you drive a big rig tighten the living hell out of the knobs so it stays in place
AmeliaRodriguez
