something about the audio doesnt quite sit right at shut down.
really i didnt touch shutdown sounds only the animation
@goose,,,
just reflash with odin
@scott , are you calling me an SOB?
Also. I still can't seem to get rw access to the system folder in sdk. I've used Astro to install them from the sd card and they work fine.
Is there any full proof way to push the apps you have linked on the first page?
I can't mount, remount and all else gets me a permission denied or system directory is read only error. I spent hours earlier scouring the internet for a solution and turned up nil
@goose,,,
i have no idea what to do.. theme still is missing
what do you mean theme is missing?
the main background image was missing, I had to go in and set up the scrolling/number of home screens/etc.
It loaded with my old image stretched wayyyyy out and blurry, and with 3 home screens, I can't seem to get rid of my pattern lock screen also.. it's super frustrating and it gets bogged down.
also the carbon fiber is still set as the default for the options. not the drop down but the bottom options.
the default image is only set for the first flash or if you wipe your data.
the patch was suppose to fix the carbon fiber.
and i never tried the pattern lock ill have to look into that , best way is to backup your data with titanium and reflash , then restore missing apps and data
I see now. I jumped right to A4.. I never used the first 2 or flashed them, no wonder that's missing.
As for the carbon fiber, I'm not sure which patch that is. I'm running A4 and the patch was pulled.
All my data and apps are still here and I'm still rooted (to my knowledge)
So now do I have to upgrade to the ED2 to get altered beast???
