Battery Percentage in JB
blg923
330
Does anyone know if we will get the battery percentage indicator in the JB update?
Sent from my DROID RAZR MAXX HD using Tapatalk 2
blg923
330
Has the percentage? Not sure what you mean by your reply.
Snareman
2,356
33
48
No. Not that I'm aware of. At least not up in the notification bar at the top. You'd have to root and get a ROM with it or just get an app like I did. I liked it better when I had a ROM on my Nexus that replaced the battery icon with a %, but no go so far on this phone.
sicario666
2,928
365
83
No need to root. Use power toggles. It will allow you to place a battery percentage in the notification bar. Also allows you to customize toggles in the notification pulldown.
https://forums.androidcentral.com/e...pps/details?id=com.painless.pc&token=1hiNaqUi
Sent from my DROID RAZR HD
Snareman
2,356
33
48
sicario666
2,928
365
83
Oh OK I see. As for a native %age. Nowhere to be found. There's only one ROM available right now. Which is a stock ROM. No percentage there. Obviously if I'm using the toggles app :)
Snareman
2,356
33
48
Yea, hopefully eventually there will be some decent ROM options and choices.
blg923
330
I thought I saw JB running in the Nexus 4 stock with the percentage, maybe I was wrong...sucks, not sure why they don't add it.
McIrish
46
That widget is called Circles and its still in JB. Works as it always did except you can't select desk clock mode from in it anymore. But, there is a seperate clock app for that now.
Potent68
13
Our circle apps on our Razr Maxx HD's have NOT changed since updating to Jelly Bean this evening. They still show the percentage and the colored circle around it in the far right circle like they always have. I hope that helps. :)
myRT
153
Sent from myRT's Maxx HD
Yep! Lovin' it. I never used the circles before..used nova launcher and a battery app. Circles was updated and more accurate so I've been using this the past week and liking it so far.
Eclipse2K
5,722
107
I would love to use Circles but I noticed a 20% extra battery drain. Is there any hidden way to change the weather update schedule to prevent this?
dirkbonn
59
Even with the circles widget in JB the battery percent indicator is only available on the homescreen that the circles is on. I use the app "Battery Notifier Pro" which puts the battery percent indicator in the notification bar at the top. This way I can see the battery percentage on any screen I'm viewing at the time. Battery notifier pro also monitors phone temperature, battery voltage out to 3 decimal points. Also have the battery percentage in various colors of your choosing, also you can have sound alerts.
I'm now just patiently waiting for the release of my next smartphone (after my current Maxx HD) sometime in the Summer of 2014. :cool:
rbess1965
654
86
Power toggle question. How did you get two rows of controls in your notifications area?
Sent using the Amazing RAZR MaxxHD
smokedog87
