I would like to buy a factory-new tablet (Galaxy Tab S6) so I would like to check if the device has ever turned on (since the production date) and also how to make sure no factory reset had done yet.
There is no way to access that kind of data (especially since factory reset does, indeed, wipe all record and data on the device).
Do you know that is for sure unavailable to Samsung devices? On my LG V60, I can go into the About Phone options in my settings and find the date of last factory reset. So it is technically possible if a manufacturer implements it, I just have no direct experience with Samsung in this regard.
