But can you do a long press on the home button on your Droid and pull up your open applications? THen isn't it just a matter of choosing the app you were wanting to switch to? I'm truly asking because I have the Pre now and am getting the Evo on the 4th.
Does anyone have a review on how Android (specifically HTC) handles multitasking? I'm familiar with Palm Pre's multitasking and I'm wondering how Android compares. Thanks!
Most apps will show an icon of some sort in the notification tray while they are running. You just slide this open and click on what you want and it goes to the app. Holding the home button only shows the 6 most recently used apps not the currently running ones.
I have the HTC Droid incredible and love it. Hope this helps
its unlikely. It would do away with the entire current setup of home screens with widgets, folders, shortcuts, etc. Plus could you imagine how long it would take to roll out by the carriers? Just look had how long 2.1 has taken to roll out to many phones released in the past months.
I prefer Android's system. I usually only find myself using 2 or 3 apps at the same time so being able to quickly switch between a couple dozen isnt a big deal for me personally.
