Title says it. I want to buy one of these phones, but I'm not gonna if I cant unlock the carrier (be able to insert SIM cards of other carriers). A friend used a program called blade unlock for the ZTE Blade, which gets the IMEI and gives you an unlock code (NCK, i believe it's called), and I found sites online with calculators where you input your IMEI and it gives you an NCK code to input when you turn on your phone. All those utilities were free.
Can I do so with a Galaxy W? I find only online sites which charge for it.
Also, is this an easy phone for rooting and stuff? Or is it one of those that you cannot root?
Thanks in advance for all the help.
~andrepd
~andrepd
