I have a Droid Incredible 2 and I purchased a wallpaper and am unable to edit it with any apps, I can't even send it to the SD card. Is there any way to make it fit correctly on the screen? right now it's really big. thanks.
Purchased wallpaper usually means they were worth the money, but it depends on what they actually let you download.... and if it's an app that actually gives you the wallpaper, then I'd say no. You might have to contact the programmer. You really are not giving us much information about the wallpaper, only that you purchased it and you can not send it to your SD card. How about some more details, without going overboard.
Maybe you can do the same thing with a file manager like astro file manager? If you find the app data and then the picture you can move it to the media map or something like that.
I don't know if this works though...
Just something that I would have tried.
