Real basic question
utupelo
Active member
Aug 6, 2011
34
I've been rocking Android devices for quite a while but I don't understand something very basic. What is USB storage? My Note says I have 8.85GB of 10.84GB available? How can I use that space? Is it only utilized when I have the phone connected to my PC?
Yes I have searched the Forums.
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
It's space available on your SD card. You can store files on it, or you can use an app like Link2SD to install apps in that space.
S-Doo-1965
228
15
The note has 10g of internal storage similar to an SD card. You can use it for anything you can do with a removable SD card. When connect to a PC is shows as a drive.
The Note also has an SD card slot for up to a 32g (some have used a 64g) microSD card. Both will show as drives on your PC.
Hope this helps.
srkmagnus
Retired Moderator
May 23, 2010
13,434
210
Keep in mind that you will not have access to the entire memory available on the device. Some is reserved for other purposes. But that's why you have an expandable memory slot for additional storage if you need it.
